3rd gen Trans Am fuel line question
I need help finding the fittings to change the stock fuel supply line and return fuel line to 6AN, so I can connect the new 6AN lines to the fuel pressure regulator and the LS1 fuel rail. My car original motor was a 305 TPI.
Thanks in advance
Thanks in advance
There many option to do this. first you need to tell us what and where you plan on connecting into the stock location to the AN -6. From the rear tank area or the front engine area. What regulator (stock or aftermarket). etc.. etc..
Try searching from some of the other 3rd gen F-Body swaps and see what they have used and how. Also try Hanks 3rd gen, they have everything you need to covert.
You can alway use a Compression (Hard line) to AN -6 adapter and then use SS lines and other AN fittings.
The fuel pressure regulator is a Aeromotive EFI #13109, I will be mounting it in the engine area on the wheel well, were the factory fuel lines from and to the tank end.
Originally Posted by Rick Speed
summit racing caries the fittings you need. they are russels fittings.. I know one part number is RUS-640850
Thanks for all the help.
