pro stars - 15x8 vs. 15x10
Old 02-19-2007, 08:17 AM
nomorews6's Avatar
Default pro stars - 15x8 vs. 15x10
what is everyone running? What is best for the street?
Old 02-19-2007, 07:12 PM
2_wacko's Avatar
It would be best to run the 15x10 for more bit. There is more grinding of the caliper when running a 15x10.
Old 02-19-2007, 07:20 PM
SiL3NtXWS6's Avatar
go big or go home
Old 02-19-2007, 09:20 PM
NA$TY-TA's Avatar
Its the other way around..... there is more grinding for a 15X8 then a 15X10.....
Ive had both.....
The 15X8's(5.5" BS) first with 275/60/15 M/T ET Street Radials....
15X10's (7.5" BS) with 28X10.5 ET Drags
Current 15X10's (5.5" BS) 325/50/15 M/T Et Street Radials...
Really its what ever you want.....
If you are wanting to sat with about the stock tire size a 15X8 or 10 would work with a 275/50/15 radials...
Old 02-19-2007, 09:28 PM
LS69TA's Avatar
I like the look of a 10" rim better. There are plenty of stupid fast cars on 8" rims, so it's mainly just whatever you want to go with.
Old 02-20-2007, 02:05 PM
z28misfit's Avatar
I'm running into the same question as the poster. Just wondering what backspacing guys are running with 15x8 draglites, I feel a 15x10 would be good also just don't need a 325/50/15 tire on my car. Want to do as little cutting and fitting as possible.
Old 02-20-2007, 02:28 PM
LS69TA's Avatar
5.5" on a 15x8.
Old 02-20-2007, 04:11 PM
z28misfit's Avatar
Thanks for the input.
Old 02-21-2007, 10:01 PM
datsbad's Avatar
Guys , I have a set of 15x10's with 7.5 bs , I also have 325/60/15 Mickey drag radials. They dont fit !!!!!!!!!!!!!
What have I done wrong?
the tire hits right near the rubber bump stops.
Old 02-21-2007, 10:20 PM
SiL3NtXWS6's Avatar
Yes, you cut the bump stop off. Just like this: Hammer the **** out of the fender too... Until it bends back and you have bare metal showing all over where i diagramed. Sorry, but you should have done some more research before diving into it.
Old 02-21-2007, 10:30 PM
datsbad's Avatar
what are you doing with that little torch in the pic? Thats funny!
are you running a spacer on there?
Old 02-22-2007, 03:52 AM
skinnies's Avatar
the 325's won't bolt right on, they will take a lot of work to get them to fit, I know I'm running them on 15x10 prostars with a 7.5" back spacing, which is the correct back spacing.
Quick Reply: pro stars - 15x8 vs. 15x10
