TSP Duals w/ stock mans and Y?
Anyone tried to mate up a TSP true dual with stock manifolds and y pipe? I know it seems like a stupid question, but in California headers are verbotten unless you're willing reinstall the manifolds before your smog check and even then you could get caught on a spot check. So I'm considering cutting the stock Y just after the cats and welding up the TSP duals then welding up some pipe after the bulets to bring it under the axels and out the back.
Anyone tried this already?
Originally Posted by SmokeySS
Look into the Bassani kit.
I looked at that, but I actually want the under axel look. I want to be able to see the the dif cover from the back of the car. I know that's really just an aesthetic thing, but I hate that pipe going across the whole back of the car. Same reason I don't like the loudmouth.
You're not going to lose any flow with the Bassani kit, especially on stock manifolds. That's what it was designed to connect to. To connect the TSP kit, you're going to hvae to have your exhuast shop fab up extensions to run from the end of the TSP kit to your stock manifolds. I ran shorties and Bassani duals and made 344 rwhp. It's actually quite a nice combo.
Tech Resident
just buy the bassani kit and weld in 2 electric cutouts before the axle.
Originally Posted by GT Griller
I think duals that dump before the axle are illegal everywhere on account of the fumes being to close to the passengers.
Tech Resident
Yes, dumps are illegal, thats why I want to run pipes after the bullets "under the axels" as indicated above. I'll check into a local shop and see what they can do and how much, I've seen some hack jobs on the internet from custom stuff so I was a bit worried about doing that.
honestly dude, your best bet is to either get the bassani true dual system, or simply get a set of used shorties with a CARB number and get your duals custom made. i'd go the second route if i were you.
