Cam ?
Old 02-24-2007, 08:17 PM
TorchRedZ's Avatar
Default Cam ?
Im going with a SDPC 347 with a 2cc dish piston, and using 59cc chamber heads. Whats the highest lift cam that i could use?
Old 02-24-2007, 08:20 PM
brad8266's Avatar
Duration will limit you more than lift will. I barely cleared with 232/236 .575 112 with -2cc pistons and 57 cc heads.
So if I were you i wouldnt stray much over a cam of my size.
Old 02-24-2007, 09:07 PM
TorchRedZ's Avatar
The problem is that i bought the car from somebody and we know that it is a 224/230 with a 6??/6?? lift at 112+2 and since i was ordering the new motor i was wanting to see if i would still be able to use that cam or have to order a new one. Im guessing that its not much over 600.
Old 02-24-2007, 09:17 PM
brad8266's Avatar
The way to see is to clay it and check the PTVC
