Many Parts For Sale - Houston, TX
UMI Performance adjustable torque arm. This is designed for vehicles with longtube headers. Steel construction. $300 (brand new) local sale only
https://ls1tech.com/misc/selling/DSC01972.JPG
Racetronix 1000 rwhp custom fuel system. This was a custom setup I ordered for a turbo racecar project, but never installed it. The kit comes with two Walbro 255L/hr inline fuel pumps, two fuel filters, two pump mounting kits, pump fittings, Y-block splitter, and a custom plug-n-play wiring harness for a car with a hatch mounted battery. $400 plus shipping.
https://ls1tech.com/misc/selling/DSC01964.JPG
https://ls1tech.com/misc/selling/DSC01965.JPG
67-69 Camaro front brake kit. This kit includes two 98-02 Fbody brake calipers (used) and two brackets that adapt them to 67-69 spindles. Your 67-69 hubs must be machined down on the OD and then you can use 98-02 rotors and pads. Missing a few bolts for the calipers. $125 plus shipping.
https://ls1tech.com/misc/selling/DSC01959.JPG
1 box of 16ea PAC valvesprings. Same item as Comp 26918 springs, since PAC manufactured them for Comp. $150 per box (brand new) plus shipping.
https://ls1tech.com/misc/selling/DSC01952.JPG
Superwinch GP2300 winch, perfect for mounting on your car trailer. Has cable remote, 60 feet of cable, 2300 lb pulling capacity. Also have the optional wiring harness for your truck, to put a power jack on your rear bumper for it. $285 for both plus shipping (brand new)
https://ls1tech.com/misc/selling/DSC01956.JPG
https://ls1tech.com/misc/selling/DSC01957.JPG
https://ls1tech.com/misc/selling/DSC01958.JPG
SOLD!!! 1998-2002 Camaro tail lights. 32K miles, excellent condition. $80/pair plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01951.JPG
SOLD!!! 2005-2007 Mustang - BMR progressive lowering springs part# SP009. Box never opened. $175 plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01953.JPG
SOLD!!! 1998-2002 F-body dash airbag and sensor. Removed from a 1998 Firebird. $100 plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01954.JPG
SOLD!!! 2005-2007 Corvette Z51 brake rotor hats. These cover up the rusty hub area on the factory rotors. Ecklers Item 49258. Only works with Z51 2005-2007 Corvettes. $100 plus shipping (brand new) SOLD!!!
https://ls1tech.com/misc/selling/DSC01955.JPG
SOLD!!! 2005-2007 Corvette and GTO - LS2 throttle body spacer. Vararam brand. Never used. $40 plus shipping SOLD!!!
https://ls1tech.com/misc/selling/DSC01960.JPG
SOLD!!! 2005-2007 Corvette tire air pressure sensors. 1K miles. $100 plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01961.JPG
SOLD!!! LS1-LS2-LS6 CompCams XE-R custom camshaft. Specs are 232/236 114 LSA. 0.595 intake lift, 0.601 exhaust lift. $300 plus shipping. (brand new) SOLD!!!
https://ls1tech.com/misc/selling/DSC01962.JPG
SOLD!!! MTI "X1" Custom camshaft. Specs are 230/227 114. 0591 intake lift, 0.571 exhaust lift. Only 4K miles, perfect for an all-motor or turbo equipped car. $200 plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01963.JPG
SOLD!!! APS brand 99+ LS1 sheetmetal valvecovers. Includes GM O-ring seals and bolts. Tall style to clear aftermarket rocker arms $300 plus shipping (brand new) SOLD!!!
https://ls1tech.com/misc/selling/DSC01966.JPG
SOLD!!! Eastside Performance 99+LS1 sheetmetal valvecovers. Uses GM O-ring seal (not included). Missing bolts. $220 plus shipping. SOLD!!!
https://ls1tech.com/misc/selling/DSC01967.JPG
SOLD!!! 1994-2006 Dodge 2500/3500 2WD truck front coil spring spacers. Daystar brand. These lift the front of your truck to make it even with the rear of the truck. $50 plus shipping (brand new) SOLD!!!
https://ls1tech.com/misc/selling/DSC01968.JPG
SOLD!!! Pair of 317 casting 6.0L truck LSX heads. Complete, low mileage. $225 local sale only
SOLD!!!
https://ls1tech.com/misc/selling/DSC01969.JPG
https://ls1tech.com/misc/selling/DSC01970.JPG
https://ls1tech.com/misc/selling/DSC01971.JPG[/COLOR]
SOLD!!! 6.0L LQ4 iron engine block with LS1 crankshaft. No photo since it is in storage, $475 for both. SOLD!!!
SOLD!!! 2005-2007 stock Corvette hood. Factory black paint, 5K miles. Excellent condition. $300 SOLD!!!
SOLD!!!
Tony,
I was wondering if you'd be interested in selling the 6.0L block without the crank? I'm currently gathering information for a 408 for my pickup. BTW I'm A_W_O_L's brother. I met you at Conley's Dyno day. I was also wondering if it is a stock block, or has it had any work?
Thanx,
Chris
Thanx,
Chris
Originally Posted by VIPRETR2
The link for your pic of the X1 cam should be
Too bad that's not on a tighter LSA or I would take it
hey nine would you do me a huge favor and weigh the torque arm for me...maybe you on the scale with it minus the weight of you just on the scale i would really appreciate it...thanks
Chris
Chris
