? about Mac mids
Old 02-26-2007, 08:51 PM
miamifan3413's Avatar
Default ? about Mac mids
I'm going to be installing mac mids in a week or so & did a search, however I didn't see anything about needing o2 extensions for the install. Will the front o2's reach or do I need extensions?? If so, what size extensions do I need??? Thanx
Old 02-26-2007, 08:53 PM
Cop Car's Avatar
dont even waste your time. longtubes or no-tubes
Old 02-26-2007, 09:24 PM
Assman's Avatar
I just did mine this past weekend. One will reach (barely) but the other is about 1" too short. I used the vette o2's on mine.
They yeild a nice power gain btw. Sound pretty good too. I got a killer deal on mine otherwise I would've gone LT's.
Old 02-26-2007, 10:11 PM
WILWAXU's Avatar
MAC's work well, although there are better choices out there now.
You shouldn't need extensions. There is usually enough "stretch" in the stock harness to work. Just be careful on the passengers side. Make sure the wires are zipped tied away from the headers.
Old 02-26-2007, 10:53 PM
I got tooo good of a deal to pass up on these Macs also.....from what I've seen they only make about 5whp less up top than LT's & thats the only difference.....hopefully my front o2's reach
Old 02-26-2007, 10:57 PM
You shouldn't need extensions. There is usually enough "stretch" in the stock harness to work. Just be careful on the passengers side. Make the the wires are zipped tied away from the headers.
I hope I have enough stretch.....should I buy the 12" extensions to be on the safe side of things??? I just want this install to go as smooth as possible....Thanx for the advice bro
Old 02-26-2007, 11:04 PM
1ORANGEWS6's Avatar
I went and bought a vette O2 like ASSMAN said. I picked up 17 rwhp and 16 rwtq with my Macs. I didn't think that was too shabby for what I paid for them.
Old 02-26-2007, 11:18 PM
Bird-Of-Prey's Avatar
I think the 02's are hit or miss. I didn't have any problem with mine reaching on my '99 when I had my MAC's.
Old 02-26-2007, 11:22 PM
I hope I have the same luck.....Does sound like hit or miss....I hate these situations SWEEEET ride u have there
Old 02-27-2007, 12:55 AM
Blk97WS6's Avatar
i also didnt have any problems with the o2s reaching when i had my mac-mids.
Old 03-01-2007, 07:55 PM
gillbot's Avatar
o2's will reach. when you install them, try from the top. Pull the coil packs, valve covers, steering linkage and maybe the starter. They should drop right in.
Old 03-02-2007, 12:25 AM
Damn.....do u really have to pull all that???? Thanx for the warning & tip I think I'm gonna try putting them in from the top by just removing the coil packs, EGR, steering linkage Does anyone know if you gotta cut the tab off the block to get these in???
Old 03-02-2007, 05:28 AM
SStheBest's Avatar
ok the valve covers no, the linkage no, and the starter HELL NOO!!!
SStheBest's Avatar
i have macs and no that crap doesnt need to come off
Old 03-02-2007, 08:31 AM
gillbot's Avatar
I've installed about 20 sets of MACs, thay all go in easier from the top. Not to mention you don't need to get the car very high either so working in a driveway is a piece of cake. The only car they didn't go in this way was my wife's vert.
Old 03-02-2007, 10:52 AM
Thanx, I will be goin in from the top....do you HAVE to take the valve covers off & starter???
Old 03-02-2007, 11:38 AM
marv's Avatar
I disagree...I've had Mac's and they made quite respectable power. Numbers in my sig were with the Mac mids and ORY. And, I've read many other instances where folks will agree.
Now I will say, that I am switching to LTs...not due to dissatisfaction with the Macs, just because I have the car apart, had the money for Kooks and thought now would be a good time to do it.
Too each his own...I suppose...
Old 03-02-2007, 11:39 AM
marv's Avatar
+1...they are easy to install. My passenger side comes out the top and the drivers drops right out the bottom.
That is one plus to running them...
Old 03-02-2007, 05:20 PM
Assman's Avatar
I only had to take off the coil packs, plugs, wires, and the passenger valve cover. It was a pretty easy install, fairly quick too.
Old 03-02-2007, 11:32 PM
Sounds good man....thanx for the input....nice SOP difference???
