not starting after h/c install
Old 02-26-2007, 09:54 PM
stangnightmare's Avatar
Exclamation not starting after h/c install
so yea i'm pretty sure the car is getting no spark or fuel. pulled the spark plugs no spark and no fuel in the cylinder. i've checked every thing i can think of. could it be a bad tune? i sent the pcm of for a mail order tune and have no idea what they did to it. any help at this point would be great, i can't wait to get this thing running!!!
Old 02-26-2007, 09:55 PM
i checked every ground and plug i can think of (the three grounds on the back of the driver side head, cam sensor, etc.)
Old 02-26-2007, 11:26 PM
JRracing's Avatar
Does it have oil pressure while cranking? Are you sure you checked EVERY plug? Even under neath?
Old 02-26-2007, 11:42 PM
nukeemall454's Avatar
so i take it you just installed everything, in that case id go back and make sure everythings connected nice and tight
