Compression ?
Compression ?
WHat compression will I be at if I run a set of stage 1 PRC LS6 heads on a stock LS1 bottom.The gaskets I will be using will be a .062-.072 thickness. I was going to run a NA setup but plans have changed and I will be doing FI instead.So I want to drop the compression to run a decent amount of boost.
