locked converter durig 1/8 mile drag
Old 03-01-2007, 09:05 PM
cjg454ss's Avatar
Default locked converter durig 1/8 mile drag
is it bad to lock the converter. i have an auto ss, nitrous midwest converter 3600 and make 600-625 rwhp. is it bad to lock the converter after say 40 mph? ive locked it on the dyno to see the hp difference and itss about 25 rwhp. what do you guys think?
Old 03-02-2007, 07:20 AM
cjg454ss's Avatar
ttt ttt
Old 03-04-2007, 08:22 PM
TJ
TJ's Avatar
i wouldnt do it.
tranny temps go up when you lock the converter.
dyno is pretty rough on locking the converter, track may not be any worse, but you are decreasing the life of the tranny, IMO.
Old 03-04-2007, 09:49 PM
jay_99z's Avatar
Originally Posted by TJ
i wouldnt do it.
Wouldn't there be more heat with it unlocked? Now....I could see it causing more wear on the TCC clutch if it wasn't designed to be locked at WOT...
Old 03-04-2007, 11:48 PM
LS1Tech Sponsor
performabuilt's Avatar
There is only heat generated when your RPM is beloow stall speed of the converter , And unless you have a multidisk clutch converter it is not designed for lockup at WOT though it may take it for a while the total life will be diminshed greatly ,
Generally also unless you have a very loose (too loose)converter there is no advantage to locking at WOT , In fact many people say they show lower ETs when locked.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-05-2007, 08:25 AM
Ragtop 99's Avatar
40 mph is the bottom of second gear and locking in second gear will likely lead to an early tranny death unless your tranny is built for it.
