after header miss -- 02 sensor?
Old 03-02-2007, 04:44 PM
sledneck687's Avatar
Default after header miss -- 02 sensor?
wll i installed my headers, and took it for a drive today, even though now i wish i hadnt(got stuck in 1/2 inch of slush geting out of the driveway), and it had a really bad miss under load. I was thinking that it was the o2 sensors being bad, because of the ceramic coating. would this be the reason why it has such a bad miss. Im sure its not the spark plugs because the headers didnt even touch them when they went in, they just slipped in so easily. if its the 02 sensors, i will jsut put my other 2 in from the stock setup. any help will be greatly appreciated. Thank you--Jarett
Old 03-02-2007, 04:55 PM
Stephen Griner's Avatar
Change the spark plugs, Even if you dont think that is the problem. I had the same problem, changed plugs and wires and no more miss. I had to change the plugs twice before I got some good ones(broken insulator).
Old 03-02-2007, 05:00 PM
2001NBMZ28's Avatar
No codes yet? First thing I'd suspect is a bad plug or plug wire arcing on the header somewhere. Also check to be sure you didn't burn an 02 sensor wire on the header - check the ENG SEN fuse.
Old 03-02-2007, 05:27 PM
it definately has codes, i !egr, !air, !rear o2's, but i havent gotten a chance to scan em since i dont drive the car in thte winter, just wanted to drive it today cuz the roads are clear.
Old 03-02-2007, 05:32 PM
it seemed to be ok just cruising, then when i get on it, it breaks up really bad.
Old 03-02-2007, 05:41 PM
cookba's Avatar
check plugs. try resetting the pcm
Old 03-02-2007, 08:05 PM
MY02REDWS6TA's Avatar
I agree change the plugs. It doesnt take much to crack one. Also make sure you hear/feel the 'click' when putting the wires back on. I was obsessive with that when I put my MSD's on. I thought a coupe were seated and they weren't.
Old 03-02-2007, 08:30 PM
99huggercamaro's Avatar
broken plug or a broken wire...every1 does it... i know i did.
Old 03-02-2007, 10:00 PM
thanks for the reply everyone, now that i think of it it might very well be the wires. Its always a pain in the *** to get them on, and i am never completely sure if they are on or not, ill give it another try tomorow. thank you
Jarett
