???01 ecm swap to a 02???
Old 03-04-2007, 12:05 PM
headsupkid01's Avatar
Default ???01 ecm swap to a 02???
I recently wecked my 01 z28 thats in my sig So i bought a 02 ss and plan to swap the motors. The thing is the ecm is tuned for my h/c motor, and i know there are security procedures when replaceing computer. The other thing is the z has ASR and the ss dosn't. so should i swap the ecm or just fork out the money for a retune.
Old 03-04-2007, 12:34 PM
wait4me's Avatar
You should be fine.
The relearn for vats should be the only thing that is needed. Or just grab the BCM and plug it in.
Old 03-04-2007, 12:54 PM
I know the vats procedure is a pain it takes like a half hour of turning the key on and off, i've done it on a couple of cars, but only with a new ecm. I didn't know if there was a vin code in there or something crazy like that. But if its going work thats just going to save me money for a tune.
Thanx for the help.
Old 03-04-2007, 01:24 PM
2xLS1's Avatar
I've seen PCMs swapped between 01 and 02 F-bodies and never had to mess with VATS. A friend totaled his tuned 01 and put that PCM in his new 02 and it worked with no VATS relearn.
Old 03-04-2007, 01:34 PM
The 01 has ASR and the 02 dosn't, will this thing start throwing abs codes. and mess things up.
Old 03-04-2007, 02:32 PM
2xLS1's Avatar
The cars I was talking about were the same way. Never caused any problems.
Old 03-04-2007, 02:37 PM
That is great news. Thanks for the info
