Need help on engine swap
Rehab is for quitters...
Try here: https://ls1tech.com/forums/forumdisplay.php?f=28 it is the forum called "Conversions and Hybrids - LS1 Engines in Non-LS1 Vehicles".
Good luck on your swap. At first it might seem a little intimidating if you haven't done a swap before but if you search through the forums you will see its not that bad. You will need a bigger radiator, an electric fan, a fuel pump/ regulator, a larger clutch master, a shortened drive shaft. Search for those items and you will have most of your questions answered.
I've been driving my LS1/ FC for nearly two years now. I garantee you will love the car with an LS1 under the hood !!!!!
