Did i mess up my PCM?
Old 03-09-2007, 04:56 PM
WhiteFormula98's Avatar
Default Did i mess up my PCM?
Ok, so i did the window mod to make the window roll up faster and for that i had to take out my pcm, so i did and then dosconnected the wires then after that i plugged everything back in and the code po785 shows up? did i mess up my pcm cuz this has never popped up before and recently i had my transmission fluid changed any advice will help?
Old 03-09-2007, 04:59 PM
LS1TECH Sponsor
foff667's Avatar
looks like its a transmission solenoid code...probably unrelated & just coincidence.
Old 03-09-2007, 05:02 PM
Well could a transmission fluid and filter change cause this and seems to idle lower as well
Old 03-09-2007, 05:24 PM
ttt top nrrd some help
Old 03-10-2007, 12:19 AM
01WS6/tamu's Avatar
just one of those **** happens things. trying working in a shop this crap happens on a daily basis. Is the tranny shftn funny or is it ok.
Old 03-10-2007, 08:45 AM
it seems to shift fine, doesent idle as high now it seems, not as much flow coming out the muffler, not as loud as normal, but there is a burn mark on the blue connector 2 the pcm in one of the holes
