2 bar map and adapter part #s
Old 03-11-2007, 10:55 PM
WindWalker's Avatar
Default 2 bar map and adapter part #s
As it says, I couldn't find these part numbers in any sticky/search. As ya might know, the adapter is needed to fit the stock harness. Thanks in advance.
Old 03-11-2007, 11:02 PM
2002ws-6's Avatar
The 2 bar cobalt SS map sensor does not require any adapter. You do need to modify the one mounting ear on it. The stock harness will reach the sensor its about 1/4" shorter than the OEM Here's the correct sensor number 12580698 and a link to the modifacation
https://ls1tech.com/forums/forced-induction/642799-colbolt-2-bar-map-sensor-install.html
Old 03-12-2007, 11:41 AM
WindWalker's Avatar
Tnx a lot!! Looks like you and I have the same car and almost the same set up.
