Interior LED Help
Interior LED Help
I read keliente's write up on the interior LED modifications. But I am not able to do the headlight swith and TCS switch since those require soldering and resistors. I was wondering if anyone on here would be able to do this for me. I want to get them done with red LEDS.
Anyone?
Anyone?
I assume you have a TA. If so i have a headlight switch that i soldered in a red led into. It works fine I just swapped from the TA dash to my 97+ Camaro dash. If you're interested I'd do $15 shipped for the switch with the light.
I have my 97 headlight switch out of my car, I see where I need to solder, I have two led's, a 5volt one and a 12volt one, both red. Should I just solder one? Perhaps someone could tell me what resistor I need, 470ohm?
