truck fuel rails w/ corvette regulator
Old 03-13-2007, 12:02 AM
C for Chevelle's Avatar
Default truck fuel rails w/ corvette regulator
i have a '04 6.0 w/ the return line coming right underneath the feed line at the back of the manifold.. my question is can i run the corvette style filter/regulator and only run the feed line to the intake? will i be able to just plug the return line? i'd rather run 1 line if possible and run the return right out of the filter/regulator near the tank...
Old 03-13-2007, 12:08 AM
01WS6/tamu's Avatar
You can use the vet regulator. Then you just run one pressure line up to the fuel rail. You have to have a return line it is mandatory. Your chevelle may not have a stock return line I am a little rusty on the older cars. If it does not you will have to run one. But what you can do is where the fuel filler neck is, if it has a smaller 3/4" pipe that allows it to feed fuel back into the tank when filling the tank you can t into that pipe and splice in your return line at that point. All it has to do is make it back to the tank that will save you have to do tank mods etc. You also might have to upgrade to a 3/8 pressure line if your car has 5/16 most of the BBC's and later chevelles had the 3/8 hardline on the frame.
Old 03-13-2007, 12:13 AM
if i use the corvette regulator and run the return from that to the tank, do i still need to hook up a line from the return on the intake?
Old 03-13-2007, 12:28 AM
sawzall wielding director
G-Body's Avatar
No, because the vette regulator would take care of the fuel pressure, you could then block off the return line on the fuel rail.
Old 03-13-2007, 12:40 AM
thats what i was thinking/hoping for!
Old 03-13-2007, 08:10 AM
patgizz's Avatar
thats looking like the way to go for most swaps. the less line fuel has to travel through, the safer i feel should a fitting leak/line rust/plastic line chafe.
does anyone know the proper plug for the return line side of the fuel rail to do this "conversion"?
Old 08-11-2013, 05:34 PM
ryanleiker's Avatar
Does anyone know the answer to this?
I may need to go this route until I can find an f-body intake setup.
Old 08-11-2013, 06:50 PM
ls1nova71's Avatar
I don't think its a good idea to block off the return. I would get a returnless rail if you want to run only one line. You would have two regulators with a Vette filter and a return style rail.
Old 08-11-2013, 07:12 PM
LS1MCSS's Avatar
3/8 tube cap. http://www.grainger.com/Grainger/PARKER-Cap-1PZL7
Old 08-11-2013, 07:58 PM
ctd450's Avatar
Run your supply and return lines right to the fuel rail and skip the corvette filter.
Old 08-05-2017, 01:56 AM
Voodoo714's Avatar
I just did this same set up on my nova with a 5.3 , ran fuel to yhe feed and blocked off the return on the rail and ran a return style filter out back....and it did not work, when i turn on my fuel pump and TRY and start the motor it wont fire, but i tur off the fuel pump, the engine fires right up....but if i turn on the fuel pump the engine bogs and dies.....so i got two options....get rid of the return style filter and plug in the returnline on the rail...or go to the junk yard and pick up a returnless system....
Old 08-05-2017, 09:21 AM
33willys's Avatar
Default Fuel rails
Long story but I converted mine to returnless and used a set of LS1 rails. Need to make new brackets for the fuel rails but that's a 30 minute job. There will be some extra expense with various fittings and adding a Schrader valve or small pressure gauge at the dead end of the new rails. Worked well for me.
Attached Thumbnails truck fuel rails w/ corvette regulator-intake-6-005.jpg
Old 08-06-2017, 04:11 PM
kpeters59's Avatar
Nobody's mentioned this (and I'm no expert), but when I was thinking of going 'return-less' I discovered that you'll need to re-tune the ECM for it as (apparently) manifold vacuum affects fuel flow and such and such and what-not...so I bailed out on it, at least for now.
-KP
Old 08-07-2017, 08:42 AM
Restricted User
JoeNova's Avatar
You'll run slightly rich if you use the corvette regulator since fuel pressure won't get pulled down at idle and cruise. It'll be well within the LTFT's ability to control, so you'll likely never notice it.
Old 08-07-2017, 09:54 AM
Floader's Avatar
I have used the vett regulator on the return style rails. I run a small set screw in the return line of the rail and tig weld it in. Works good, but getting the newer style return-less rail looks better.
Old 08-07-2017, 10:09 AM
Restricted User
JoeNova's Avatar
Just grab a returnless rail off of a 04+ intake. Problem solved.
The regulator on the return style rails is MUCH better than the corvette regulator anyway. I don't see the point.
Old 10-16-2017, 07:01 PM
JONQUELL MAYES's Avatar
Want to know what you end up doing...? I have the Exact same problem and I don't know what to do...
Old 10-23-2017, 05:10 AM
gagliano7's Avatar
I have a few truck intakes with one with a returnless fuel rail. $25 plus shipping from NY.
Old 10-23-2017, 10:45 AM
APillow's Avatar
Same boat here on a Cherokee swap ordering the parts now. SKIP the BS Corvette regulator. SKIP the $$$ fuel rails. Both are a waste of $$$.
The stock truck fuel rails and regulators are good to like 600HP. Sooo why mess with it?
I am going -6, but you can convert to -8 if you would like (overkill and does not match anything Stock ID anyway), just upsize from these PN#s:
http://www.russellperformance.com/mc...injected.shtml
Check this out:
Fuel pump/tank (I'm still working on this part) to
ACDelco GF652 factory truck 5.3 fuel filter
use (x2) Earl's 991955 Blue Anodized Aluminum -6AN Male to 16mm by 1.5 Power Steering/ Fuel Injection Adapter Fitting to convert from female to -6
Connects to 3/8" pressure input side of Truck fuel rail
Russell 644123 -6AN Male to 3/8" SAE Quick EFI Adapter Fitting
Connects to 5/16" low pressure output side of Truck fuel rail
Russell 644113 -6AN Male to 5/16" SAE Quick EFI Adapter Fitting
Use the line and fittings to connect in between as needed for your application. The long runs at -6 vs -8 will def save some $.
Some crazy fitment adaptability information for the fuel filter:
https://www.wildsnow.com/20806/adapt...-to-any-lines/
All of this is available on Prime Amazon. Since this order does not add up to $99 for Jegs/Summit free delivery.
Old 11-27-2017, 06:46 AM
jmyoungblood10's Avatar
i just swapped a 5.3 with return with an lq9 without return, since the 6.0 is already returnless can I just block the old line on the truck to the tank off?
Quick Reply: truck fuel rails w/ corvette regulator
