shop charges $250!!!!
So i tryed installing my td's yeasterday and failed, badly. the system i had bought was a custom one for his car so on mine things werent really looking up to par. I ran it up to my local muffler shop and he said hes ganna have to get new tubing and mandrel bend them and stuff for the ends so theyll hook up. and named some other bullshit like they always do, well he said its ganna cost me 250$....is that alot?
I would think so, you could probably find a brand new set that would bolt up for about $400. I really depends on the set up that you have. Do you have LT or cats?
Originally Posted by presto_z
depends on exactly what they are doing....
a local shop in town charges 500 for true duals over the axel, but it is insanly nice.... you lose no ground clearence..
okay ill post up some pics....were using the same td system hes just ganna fix it cause i kinda cut it up when i was trying to instal it. well at least now i dont feel all to bad about this price..he said it will be done tomarrow afternoon. il post up some sound clips and pic when i get it.....( its hooker lt's with 2.5" true duals ORX and magnaflow bullits out back with corsa knockoffs)
all hes doing is installing my td's tho, hes not making me a td set up.....hes ganna have to fab stuff up to make them work but the tds are already welded together and their!...i thought it was alot for that, but wow i dont feel soo bad now
Hmm. Okay, I sort of figured if they had to modify it to a certain extent it wouldn't be too far from a fabricated system. My quote was to fabricate TDs over the axle and out back. Good luck anyway; hope it works out well.
reguardless hes got to change what you broght in to make it fit, and thats time and labor so 250 isnt really that bad. considering most shops charge around 75 bux for labor, I would guess a shop would probally look at around 2-3 hrs for the job, so thats 150-225 for labor alone, plus any extra pipes and whatnot he needed and clamps exc
Most of these cheap prices everyone is seeing is probalby for crush bent tubing. Not many side-of-the-road exhaust shops have mandrel benders. Crush bent is super easy to do duals with.
Luke
Luke
Luke
Luke
