adjust mondo bypass valve?
i notice you can loosen the nut and screw the screw in or out on this guy.
what effect does it have screwing the screw in vs out?
I just left it set to factory adjustment, worked flawlessly.
The instructions say that the factory setting should be good for nearly anything that isn't an all out race application.
I know this doesn't remotely answer what you asked, but hey i'm just putting it out there....better than posting up in the PCM section and not getting and answer
J
J
so info is better than none
I guess I will just try it both ways. this one flutters instead of whoosh when you get off the throttle, I could be wrong but it just doesn't seem like it's opening all the way.
I have never heard a peep from mine, but I do have it dumping right out of its port into the Vortech inlet. Maybe the new T-trim will give it some exercise!
I tightened my adjustment screw four turns in to make it close a little faster, but it didn't make a big difference.
Jim
Jim
