Lunati Stroker Kit ?
Old 03-16-2007, 07:22 PM
joshluther's Avatar
Default Lunati Stroker Kit ?
What is the part on the left for? It was in the bag with the crank sprocket. Is it for the cam gear? I know what the part on the right is for.
Old 03-16-2007, 07:31 PM
Boosted LS1's Avatar
Looks like something to centre something but why not machine the sprocket properly? Guess I dunno. Does it fit anything?
Boosted.
Old 03-16-2007, 07:47 PM
joshluther's Avatar
The hex fits over the stud on the cam but obviously doesn't fit into the cam gear. There is no stud on the back of the crank for the flex plate but why would you need an eccentric there?
Old 03-16-2007, 09:50 PM
FieroBob's Avatar
You might want to drop an email to Lunati with the picture. I'm sure somebody there will be able to tell you what the part is for. Good Luck.
Old 03-16-2007, 10:07 PM
Ping King's Avatar
its to adjust the advance and retard of the cam. I have one made by comp (sister company) you put it on the cam dowel, then with all the cam bolts lookse you adjust the cam timing.
Old 03-17-2007, 08:19 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Comp and Lunati have nothing to do with eachother.
Andrew
Old 03-17-2007, 11:56 AM
joshluther's Avatar
Someone must have seen one of these before.
