Is the N-Motion single roller LS2 timing set safe on a 700+ HP engine?
Old 03-22-2007, 09:44 PM
9 Second Club NA
Dragaholic's Avatar
Default Is the N-Motion single roller LS2 timing set safe on a 700+ HP engine?
I was wondering if the N-Motion single roller LS2 timing set was capable and safe running in a 700+ HP engine or should I consider the double roller? I've been told that the double roller will work with some slight modifications. What do you think?
Old 03-22-2007, 10:15 PM
skipperbisket's Avatar
why not just run the roller master dual setup? its ~$90 and will perform flawlessly for what you are wanting to do.
Old 03-22-2007, 10:33 PM
9 Second Club NA
Dragaholic's Avatar
I don't believe Rollmaster makes a timing set for LS2s. I'm building a L92 setup and requires a LS2 set.
Old 03-22-2007, 10:52 PM
the L92 heads don't require an LS2 timing setup. However I do believe an LS2 block does. So, if you are running an LS2 block then you are right an LS1 chain wont work.
Old 03-23-2007, 05:59 AM
See5's Avatar
I am running the N-Motion double and was amazed how loose it was, even new. Much more than a LS2 chain. Not to bash but I think the LS2 is better and it works with a split front cover where as the double doesn't.
Old 03-23-2007, 06:54 AM
santiago's Avatar
i will be running it on my new set up. i ran it on my old t-rex/ls6 head set up and had no probs.
Old 03-23-2007, 06:56 AM
99Fbody99's Avatar
The set is made by JP Performance and it top notch.
I have a few 800rwhp running around on them with the stock Rolon chain.
I have however done a couple where I switched to the LS2 chain to tighen up the loosness as you described to get a cam tighter in spec.
You can, depending on which block you have opt for the new spring type chain tension .
Dave
Old 03-23-2007, 11:48 AM
9 Second Club NA
Dragaholic's Avatar
I'm using the L92 block which requires the LS2 timing set. I just didn't know if I should have my engine builder go through the extra process of making modifications to fit the double roller. I already have the single roller N-Motion LS2 timing set and was just wondering if it would be ok in a 700+ FWHP engine.
Quick Reply: Is the N-Motion single roller LS2 timing set safe on a 700+ HP engine?
