which cam is the best ?
what do you think guys for this cam which is the best :
my mod
402ci 9.3:1
AFR head 225 72cc
vortech 14.7 psi
60lb fuel injectors
1000 fuel pump
th400
moser 12bolt 3.73
Lingenfelter GT2-3 camshaft 207/220 .571/.578 118.5
oR
custom cammotion cam 234/240 .590/607 114
thank you
navy
my mod
402ci 9.3:1
AFR head 225 72cc
vortech 14.7 psi
60lb fuel injectors
1000 fuel pump
th400
moser 12bolt 3.73
oR
thank you
navy
They are very different cams, what are you planning to do with the ca?
Why would you even think about a cam as small as the first one? With the setup you have now you can do every bit as large as the second one if not bigger.
