help! coolant in intake ports!
Alright guys, i hope i didnt screw up that bad but heres what happened. I was gonna do an ls6 intake swap soon and 2 weeks ago i took apart my throtle body and egr. Yesterday one of my old buddies stoped by and wanted me to start it up so he could here it. I totally forgot about having the ******* parts off and i started the engine. It started ruff and then the idle went up really high and was bouncing off the rev limiter. Then i remembered the parts were off So today i started to take off the intake for my swap. After i got the intake off i looked into the ports with a flashlight and theres puddled of coolant in there. now what do i do?
Originally Posted by senicalj4579
is my engine gonna be toast?
if the liquid is from the tb then i think you will be fine on start up. just a lil smoke maybe. i dont know about the start w/o the TB lol, cant say that i have done that before.
i also broke a intake bolt on the 2nd one back on the pass side. think it will be ok without it?
oil pressure is now 40. yeah the damn bolt snapped off and half of it is stuck in the hole. its throwing codes now. anyone know what p0102 - maf or vaf circuit low input and p0122 - tps/pedal position sensor a circuit low input is all about?
should i just get rid of this damn car or what. its been a bad day man
ok, so i talked to eastside performance from my area and they said i should be ok. said the engine should just burn off the coolant,it may smoke and smell for a while. also need to change the oil maybee a few times. The car seems to run fine for now. Also it is smoking a little. Hopfully it gonna be ok
