Another DIY turbo build
DONE!
My wife & I have been working on this almost daily for 6 mos. It is not in the same leage as a lot of the cars on here but we love it. It is absolutely bad *** on the street. This is my first gen III engine build & first turbo build.
I want to thank ls1tech & all the sponsors that make this site possible.
Details:
LS6 Block
forged -4 cc pistons
forged rods
stock crank
AFR 225 heads
TR224-114 cam
TC 76 turbo
Nasty Stage II with my own dual pump fuel system
Full "mostly" BMR suspension
Turbo 400
Vig 3k stall
9" rear
hell I can't remeber what else, here's some pics
Details:
LS6 Block
forged rods
stock crank
AFR 225 heads
TR224-114 cam
TC 76 turbo
Turbo 400
Vig 3k stall
9" rear
Originally Posted by datsbad
who's alternator set up did you use? what belt length .
Looks sweet !!!!!!!!!!
No dyno close to us. I have taken it to ~9 lbs of boost & started getting 1 to 3 degrees of KR. I have around 150 miles on it. I'm trying to decide on what racing gas to order.
The elec cooling fan is taking a beating from heat off of the turbo. I ordered a turbo blanket from Jose.
Looks good..... what fuel are you running in it now and what tuning have you done so far?? How much timing?? What are you using for tuning??? 3 BAR setup??? Wideband???
Maybe you should try a progressive methanol injection kit...That would help with KR on the street atleast and then put some racing fuel for the track... Awesome work again bro... When I bought the KB BAP off of you your wife told me about it...She wasn't lying when she said that it's going to be nice... =)
Yeah I thought about meth but I would rather not have more stuff to worry about not working etc. I'll research it some more.
I put a drain in my tank so I can switch over to race gas when needed.
