LQ4 main caps
LQ4 main caps
Anyone here ever have a main bearing cap just fall out of an engine? Of all the engines I've built in the last four years I've never had that happen until I disassembled my 408 after it started making odd noises. Normally they are wedged in the block but the 2nd from the front one just fell over when I pulled the bolts out.
There was no friction holding it in place. It is too short to fit snuggly between the rails of the block. I pulled the bolts out and it just rocked over against the counterweights of the crankshaft.
LS1TECH Sponsor
loose cap
That main cap is sprung. The cause, possibly detonation related.
You may want to consider having steel caps installed on that block if it is a forced induction or nitrous engine. The alternative is to get a good used cap on there and align bore the block.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
LS1TECH Sponsor
replacement steel caps
The originals are powdered metal.
Steel caps are available from Pro-Gram Engineering and Callies.
The steel caps need to be fitted to the block via align boring.
Steve
Steve
Where do you get steel replacements? Are the originals powdered metal?
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
I found some but they must be made of gold at $550 a set. The boss says they're made out of that new exotic material UNOBTAINIUM.
LS1TECH Sponsor
steel caps
You should be able to find a set for around $500 racer net. Try some of the sponsors like Thunder Racing.
I warn you that the main expense is the installation. This has to be done correctly.
Steve
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
