Offset question...
Old 04-06-2007, 02:44 PM
Slow Z28's Avatar
Default Offset question...
I did a search and it didn't provide the answer I was looking for...
What the hell is it? Hahaha.
I guess my biggest question is this...
If you had two different size rims(weld pro stars)...
15x10 w/ 7.5" backspacing and it has a +51mm offset
If you have that same 15x10 w/ 7.5" backspacing and a +38mm offset
Which one of those sticks the wheel out further?
Chris
Old 04-06-2007, 02:54 PM
TheLS1Kid's Avatar
+38mm offset.
Old 04-07-2007, 10:56 AM
Slow Z28's Avatar
ok, i got it now. thanks a ton! i guess at 13mm difference, really wonder how far it'd stick out, need a mm --> in conversion time to hit up google
Old 04-07-2007, 11:00 AM
TheLS1Kid's Avatar
Not a problem man.
13mm's is a little more than 1cm.
Old 04-07-2007, 01:22 PM
Slow Z28's Avatar
yah, .5"
i was looking at the Weld Drag Magnum's that are 15x10 w/ 7" backspacing, but the offset then is 38mm vs. the 51mm of the pro stars.
i'm just trying to figure out how much further it will stick out and if that 13mm offset difference is just because the rim is .5" less in the backspace. I guess that's how the numbers come up if that's how you really measure it with the centerline of the 10" wheel.
