Hotchkis Springs. Before...After.........After
I never did post up my before and afters, so better late than never
Bilstein shocks and Hotchkis springs
Before (10-31-05)
After 2 months with springs (Jan 9, 2006)
Finally a year later (Jan 6, 2007)
Before (10-31-05)
Restricted User
Wow if you keep Hotchkis springs on your car for one year, they will turn your stock wheels into CCW505a's? I'm SO getting them!!
This is great because I too am looking at the same shock/spring/wheel combo. What size and offset are your wheels?
I think the are suppose to lower the car 1". Mine took about a monthe or so to settle to where it sits now. I like it because it doesnt sit to low and i never have problems with ground clearance. If i had to do it again though, I would go with Strano springs.
Originally Posted by 11 Bravo
I can't tell by your pics, but are you running cats? How much clearance does your y pipe have?
I don't know the offset, I just called and told them it was for a Trans Am and 2 weeks later the wheels changed from stock to CCW 505As
The size is 18x10 and 18x11 out back with 285-35-18s and 295-35-18s in Goodyear GS-D3
Originally Posted by 2002BlackSS
That setup looks very nice. Are you using revalves, HDs? How does it handle?
The only thing I can compare it to is stock springs and stock ride height. It is not a harsh ride by any means considering lowering springs and shocks and it handles real nice
Originally Posted by michaelg589
how much were those Hotchkis springs supposed to lower you? 1"? 1 1/2"?
I have my stock dimensions somewhere written down. I just have to find it and measure again to see the exact drop, but it might be off a little because my rear tires are a little taller than stock
Originally Posted by MetallicBluews6
Only thing left is the HOOD!
Future plans are a Raptor hood (little expensive right now) and a nice twin turbo system for around 550rwhp (a lot expensive right now)
LS1TECH Sponsor
define "well enough".
__________________
