Harland Sharp rockers for L92
I got a set of adjustable 1.7 rockers from Harland-Sharp.
Several Issues:
Rockers were sent without the adjusters @#%$#! which wasn't discovered until they were ready to be used since they were vacuum packed in plastic#$%&@@@#*&^!
The rockers are too big , quite a bit of machining needed to be done at the top where they were hitting the wall of the head. Recommended pushrods are too long
0.5" spacer needed if you are using the LS1 cover- spacer needed reliefs cutout at the rockers too.
LS1 valley covers fit after cutting out the center dividers on the right side.
Several Issues:
Harland Sharp L92 rockers?
I know some people have sent there stock L92 rockers over to Harland Sharp to have the needle bearing changed out but I did not know they have a set of Off set roller rockers for the L92 available.
Where did you order them from and are they actually for the L92 or are they LS1/LS2/LS6 rockers?
I sent some stockers in to them for the needle bearing treatment last week. They said the they were just finishing them up for the L92. I will eventualy get the full roller version, but I will get it running and broke in first.
Hopefully they get all of the bugs worked out.
