with a 233/239 cam or TSPv3 torquer?
Old 04-07-2007, 05:38 PM
LSGunZ28's Avatar
Default with a 233/239 cam or TSPv3 torquer?
and a set of heads that will run on 91 octane, how many have you achieved the 450 RWHP goal?
I have a 2002 Z28, M6 with an Aluminum flywheel, LS7 clutch, and 25% underdrive pulley. LTs, ORY, and LM1 as well as SLP lid, K&N.
I will be getting True duals soon, instead of the ORY and LM1.
I will be putting on Black Zr1 rims or Black Z06 rims
I just rebuilt my T-56
I am installing a Ford 9" in 2-3 weeks with a Truetrac and 3.73 gears. I know that this will eat some of my horsepower. I also have a full list of suspensions mods, I will soon be getting a Torque arm as well as a PST 1200 Hp rated Aluminum driveshaft.
With what cam and set of heads can I achieve around 450 RWHP?
I want to leave the 3.73s and its a daily driver, So I want something that will have enough torque at lower RPMs and that will run on the pump gas I am putting now. I was thinking the TSP torquer V3 or the TSP 233/239 will help me get those numbers? as well as LS6 heads perhaps and a good tune.
Thanks.
Old 04-07-2007, 05:40 PM
LSGunZ28's Avatar
Also I will be porting my T/B soon and maybe get a new MAF. I have the LS6 intake manifold already.
come to think of it, maybe I want a tad more than 450 RWP...
and all N/A please.
Old 04-07-2007, 05:42 PM
LSGunZ28's Avatar
The texas speed magic stick 3, seems like it will get me there easily, but I dont think with my gears it will be appropriate.
I also will road race this car as well as take it to the dragstrip.
Old 04-07-2007, 06:34 PM
onebadZ28's Avatar
i to would like to know if the V3 and 2.5 5.3L heads will net 450 through a M6 tranny with the same gears, and 90/90 ported by tony mamo?
Old 04-08-2007, 12:15 AM
LSGunZ28's Avatar
cmon guys, I know you're out there!
Old 04-08-2007, 10:43 PM
LSGunZ28's Avatar
Happy Easter
Old 04-09-2007, 01:47 AM
LSGunZ28's Avatar
Bump It!!!
Old 04-09-2007, 10:08 AM
SLP4CamaroSS's Avatar
233/239 because the tqr3 has to high of a lift for me
Old 04-09-2007, 01:08 PM
LSGunZ28's Avatar
yes, but how much HP will it net me and around what RPM will the peak HP be, what is stock Peak HP? like 5700?
Old 04-10-2007, 01:25 AM
LSGunZ28's Avatar
Damnit you guys! Hurry up!
Old 04-10-2007, 11:46 AM
Prin's Avatar
I got 406 out of the T3. That was with a stock pulley and ls6 intake. We left if there be cause I needed better injectors and plugs to go any futher.
Old 04-10-2007, 11:56 AM
marv's Avatar
TSP 233/239 with TSP CNC LS6 heads made the numbers in my sig...
Haven't dynoed the new setup just yet...hope to soon.
Old 04-10-2007, 12:38 PM
u prob see 0 -10hp maybe differnce between the 2
Old 04-10-2007, 12:53 PM
gnx7's Avatar
LS1Tech 20 Year Member
My previous combo-
23K mile '99 shortblock: Katech rod bolts, ported LS6 oil pump, LS2 tchain
milled AFR 205's (62cc) with GM MLS gaskets (10.7:1 compression approx)
TSP 233/239 .600/.603" 112LSA cam, stock LS1 rockers/lifters, upgraded pushrods
LS6 intake, ported TB, UD pulley, no a/c or p/s
1 7/8" long tube headers, Magnaflow 3" cats/Xpipe/muffs
alum Fidanza flywheel, RAM 910 clutch/VDS, alum Dshaft, 3:90 gears RX-7 IRS
18x10.5 CCW's with 285/30/18 MichPSCups on the dyno
I made 440rwhp/385rwtq on 91 octane with 7100rpm redline with cats on. The only thing different I would've done is use the Cometic head gaskets to get my compression over 11:1 which is still 91 octane friendly as the big cam bleeds off cylinder pressure and makes it still possible.
Big cams want big compression or you will be losing unnecessary torque.
My dyno chart showed the HP being just about flat from 6K-7100rpm... meaning the intake was the limiting factor at that point.
My car was a daily driver with 20K miles on it in 1 year and road raced about 3-4 track days and probably 15 1/4 mile passes.
IMO the power is in the heads. Don't cheap out.
Old 04-10-2007, 04:15 PM
LS1C5Vette's Avatar
yep no more than 10rwhp
Old 04-10-2007, 05:36 PM
if it was 10 hp u think it worth changing the spring out more is worth it?
Old 04-10-2007, 09:14 PM
LSGunZ28's Avatar
I was thinking of going with the head/ca, package from Texas speed. what do you mean dont cheap out? is their product not quality?
The LS1 has a stock c/r or 10.1:1 If Im not mistaken. with a stock bottom end, what heads will I need to run 11.0:1-11.3:1 compression ratio and is it safe to run higher compression without the valve getting in the way of the piston?
Old 04-10-2007, 09:15 PM
LSGunZ28's Avatar
also to the guy running IRS, with 10.7:1 compression ratio and IRS you made that much power... It should be 450 RWHP with a solid axle. what dyno did you guys run on?
Old 04-11-2007, 02:34 AM
LSGunZ28's Avatar
on what dynamometer was this reading on?
If it only made 406 WHP, even with higher a compression ratio and all supporting mods, I dont think it will still get me 450 WHP
Old 04-11-2007, 08:39 AM
Prin's Avatar
It was a dynojet...
Quick Reply: with a 233/239 cam or TSPv3 torquer?
