LT4 knock module part number
Knock Module = small square shaped module that goes into the PCM itself up on the passenger side of the engine bay up near the firewall. Knock Sensor = round sensor that you screw into the bottom area of the block on the passenger side.
Reads what the knock sensor puts out. The LT4 one is better at reading false knocks, which will change the timing, causing SOME performance loss.
Speed Density don't have them And for that, I'm a sad panda.
Isnt this backwards? I thought the LT4 was the less sensitive of the modules.
Most commonly, pistons slapping the valves (pre-ig/ping).
detonation is simply caused by timing and the fuel you have.
