aligment
Old 04-09-2007, 06:43 PM
Soltakr's Avatar
Default aligment
Problem: Need more threads on the tie rods for perfect alignment
The set up:
2002 SS
Eibach sport springs
Koni Shocks
UMI adjustable upper and lower a-arms
UMI K-member
Bear bump steer kit
I had the aligment shop thead out the a-arms to give me more lengh on the tie-rod but that just threw off my camber off more. What I would like to know is if I can cut the tie-rod at then end 1 inch or if there is any aftermarket steering rack that is more adjustable. My toe is straight and so is the caster but I had to give up 1" of neg camber. Which I know isnt bad and good for racing. I just wanted it perfect you know? Any help would be great.
Old 04-09-2007, 08:33 PM
Copy & Paste Moderator
VIP1's Avatar
LS1Tech 20 Year Member
What specs did you reach and what specs do you want to reach?
Old 04-10-2007, 10:18 AM
Soltakr's Avatar
I'll go back and try to get the print out today.
