testing for leaking injectors
i bought NEW 37lb racetronix inj and having a promblem with the car flooding in the first 5 seconds of running how can i check if one or some are leaking? is there anybody that test them?
I need to know too.I am having a problem that I think is a leaking injector.I put a fuel pressure gauge on it and in about twenty minutes it had dropped from 36lbs down to 20lbs with the engine off.But I dont know whats normal.
hashtagBMW
https://ls1tech.com/forums/showthrea...=Injector+Test
Searching turned up that.
I guess i might be helping in the wrong way though. Do you think one of your injectors is clogged? Or just not functioning at all?
Tony.
Tony.
