TR 224 and base circle question
tr 224/224 .561/.561 114
does any one know if i can run stock length pushrods (7.4") or is the base circle smaller which would lead to runnig longer ones
Also on a head cam car i should run hardend pushrods correct?
Re: TR 224 and base circle question
Have your heads been milled? If so, how much? That will determine if you can still use stock length hardened pushrods. If your heads are stock 7.400" length are fine. If your heads are milled 0.030" also, stock length are perfect too <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
earlier i was told that aftermarket cam's often have a smaller base circle therefore a longer pushrod would be needed to get desired lifts.
Was i misled?
Was i misled?
