Generation III Internal Engine - cam swap HELP!
View Full Version : cam swap HELP!
edwardswb
04-13-2007, 09:29 AM
Hey guys. It's freaky friday at Thunderracing.com...I love it. Anyways, to the point. This swap is only to hold me over until my big C.I. single turbo is ready. Not a daily driver! I lucked out on a barely used TRex, barely used Patriot Gold doublevalvesprings with locks and retainers. I'm re-using my oil pump (holds over 60 psi) stock lifters, and stock timing chain. The engine only has 40,XXX miles on it and put down 350hp/366tq. I am going to check all re-used parts for wear. I am doing the complete swap for less than $700 this way. :chug: Should I replace the valve stem seals or not worry about it? If yes, which ones out of these:
Part # Product Price My Cart Wish List
161-1428-16 K-Line 11/32 Valve Stem Seals, set of 16 $26.00
Sale! $23.40 Buy Wish
161-VS-UV5001-EO LS1 Valve Stem Seals, .500 X 8mm, set of 16 (Valve Stem seals will need to be replaced when using the Comp 26921-16 Valve Springs or the Crane 40-144832 Valve Springs.) $16.00
Sale! $14.40 Buy Wish
161-1430 K-Line 11/32 Valve Stem Seal Applicator $4.50
Sale! $4.05 Buy Wish
edwardswb
04-13-2007, 10:19 AM
Anyone?
