Cam chewed up, whats the cause
My advice is send the cam back to TSP and see what they can do.
If it is a hardening core problem Comp cam (grinder) might replace with new one.
If you would like to go over this just give me a call, advise is free.
Harold
Port Pros LLC
512-257-0222
Harold
Port Pros LLC
512-257-0222
so i have a useless cam i paid $400 for. mine is not near as bad as the above pics though.
Which springs did you put on the AFR's, I just need the part numbers. I have the installed heights for those heads so I should be able to tell you if the perssures were wrong.
As far as customer service goes as a dealer for Comp Cams I want to get to the bottom of this.
I buy and sell tons of Comp Cams parts and I don't want you guys to think no one cares when you spend cash and have this kind of stuff happen.
I will get on the phone with Comp and find out if there is a problem with these cams and get back to you.
Harold
Port Pros LLC
512-257-0222
