806 to 243
Old 04-14-2007, 07:27 PM
ez98ls1's Avatar
Default 806 to 243
What would the gains be going from a set of stock 806 heads to stock 243 heads?
Old 04-14-2007, 10:15 PM
Tainted's Avatar
ls6 heads offer like a 25rwhp gain over ls1 heads i think
Old 04-15-2007, 05:33 PM
WILWAXU's Avatar
Moving to Internal Engine
Old 04-15-2007, 06:31 PM
justin quick's Avatar
25 too 30 rear horse is what i have heard as well.
Old 04-15-2007, 07:22 PM
F-Killer's Avatar
Whats the difference if I get these two heads ported, will I get the same result?
Old 04-15-2007, 07:26 PM
Tainted's Avatar
ported ls6 heads will be better
Old 04-15-2007, 07:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Hold on a minute. That is not true at all.
For the most part....yes same thing is going to happen. IT is not like it is a different science.
They will probably be neck and neck. There isn't going to be a big difference just because one is a ported LS6 and the other is a ported LS1. Chances are, one is going to be ported (if done correctly) almost identically with the same results in mind, as the other. I just moved a thread over here explaining a little bit about it.
