coil harness for ls1
Old info I had around on this is:
coil mtg bracket 12563288 or 12562864 from rockauto or gmparts direct ~ $9
Coil harness 15301401 ~ $ 50 each on gmpartsdirect
I found some from a fellow forum member like cnichols offered - saved quite a bit from buying new (maybe you already got some from him - but others might find the info good)
A note of caution - gm is notorious for changing part numbers - and I think the 98 may have a different pn, but should electrically work (just some physical fitment differences with coil brackets if put on center stud covers).
