What have you destroyed..
This might be an interesting thread..
What have you grenaded in your car since you have had it.
Here is the list of mine..
Stock Tranny Mount- first 2 weeks of having it, got Energy Suspension one
Factory 10-Bolt Carrier- as soon as I put on my 17x9.5 Z06's with 275/40 BFG's, killed it on a test drive
Blew a Head Gasket cause the EGR Malfunctioned with the Hotcam, ran a little too lean, rebuilt the upper end.
Spun a Rod Bearing during a pass at Memphis, then spun all the Main Bearings. Killed the factory Engine with that..
Re-built the Engine with a kick *** setup, bolted on some MT ET Streets and killed the factory S.R.T.A. 4L60E(had 25k miles) as well as the Ring & Pinion in the Rear messing with a friend of mine from a roll.
Got that all rebuilt with Motive 3.73 Gears, and a fully built 4L60E with a Corvette 2000 Stall.
And the latest, ripped the Torque Arm off of the Differential Housing. That might of been partially me there..
Break it and built it better..
Lets hear them guys..
Three tranny's in my car in the last year in a half, two opti's , tires...
freind spun a main bearing and cracked the block on his LT1
my brother just snapped the front two conecting rods in his 77 camaro with the 355..lol..
Stock tranny mount first week of having it.
blew out the posi in stock 10-bolt from siding around turn to much.
Ripped the break material of the pad from power breaking. lol cheap autozone breaks
ford 9" 3rd member- 3500rpm dump on M/T drag radials
along with a bent/twisted driveshaft
1-OEM replacement opti
4- parts store opti's
1-3/4 shift fork, 3/4 synchro assy. and a set of slider keys
... and the obvious:
Gas
Tires
Oil
Gas
Tires
Oil
I grenaded my transmission on my bday at 2am racing a mach 1 on the way to the beach to get hammered last year. I really really killed that thing ... then had to sit at a 7-11 for 2 hours on a memorial day weekend, waiting for a tow truck
Opti/Waterpump
5 power window motors (<3 autozone's lifetime warranty)
Opti/Waterpump
almost everyone can account for the damn power window motors...sigh. I recently grenaded my 4l60e..but its alright..performabuild going in...knock on wood that is all i have torn up in my camaro
Trans mount, replaced with energy suspention mount
4L60e, converted to a T56
Centerforce clutch, replaced with a SPEC stage 4
Blew the yolk off the rear end, replaced with another stock one
Opti died, replaced with a stock replacement
Broke driverside rear axel, replaced with used stock unit
Blew the spider gears out of differential, replaced with used Zexel from an SS
Blew the yolk off the rear end a second time, replaced with another stock one
Broke #3 exhaust spring and bent #3 intake and exhaust pushrods, replaced all springs with Comp 987s and Comp pushrods
Wore out SPEC stage 4 clutch after 50,000 miles, Replaced it with McLeod street twin.
That brings me to where I am today. Im about to finish up my rear end install. Im in the process of installing a "built" (Kindof and oxymoron)10 bolt with 4.10s, T/A girdle, Moser axels and Zexel HD diff. Now with 4.10s and a street twin Ill probably break alot more parts.
Jeremy
Jeremy
Originally Posted by Formula350
JUST our current vehicle? Or can we list past ones?
Nothing yet, but I've fixed a bunch of things so far heh
Jeremy
2 Opti's & a set of Taylor Wires
The original T56
Broke a header bolt in the cylinder heads
Spun a bearing on the stock short-block after I did a H&C
Dropped a thermostat
I don't think I'm that bad
The original T56
The original T56
The original T56
man i'v had my car so long i cant remember everything. all i can remember is spend most of my time fixing something on saterday because i broke it friday night trying to beat someone.
Damn, im too easy on my car. i fixed the motor mount bolts (they were snapped when i got it) and wp. everything else has just been an upgrade. I need to beat my car more, lol.
-snapped the stock tq arm right in half
-tranny mount
-1/2 synchro, 2nd gear, reverse synchro, reverse gear
-tq arm mount, blew out the rubber and stretched the metal band out
-set of t-tops
-window motors
-tranny mount
-set of t-tops
-window motors
