What size Cometic?
What size Cometic?
I'm going to be running a MS4 with TFS heads. I'm just wondering what size gaskets to go with, .040 or .045? Right now I'm not sure how much milling on the heads I'm going to do, but some will be done. Flycutting isn't a concern, as I'm sure I'm going to have to do it. Any thoughts for this set up? What do you guys recommend on the milling?
With regard to the quench (squish), you'll need to measure your piston to deck height. Once this is determined you choose your gasket accordingly.
Quench= Compressed gasket thickness - piston to deck height
