ls6 cam questions?
ls6 cam questions?
my uncle scored a couple of ls6 cams for cheap, he has an 06 gto, and i have an 07 gmc sierra with the iron block 5.3.
sdpc couldnt tell me what length pushrod i should go with when these cams go in, has anyone done this swap? im new to ls series motors and i dont know if the 5.3 i have has the same basic parts as my uncles 6.0.
the ls6 cams have a smaller base circle, and that is the reason for a longer pushrod, correct? could i just subtract the base circle difference and add that to the pushrod length?
LS1TECH & Trucks Sponsor
Do you know which year model those cams are? There were a couple different part numbers which had a couple different base circles....your best bet is likely a pushrod length checker to be sure (or measure the base circle so we can be sure which length you need)!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
You could do that Subtraction, but to be sure, just purchase a Pushrod Length Checker. (Jesel and a few other places have them)
Better to be safe and on the money then using a set of dial calipers. Either way will work, but it will be closer with a nice pushrod checker.
