anyone running the trick flow track heat cam ???
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,500 RPM
Intake Duration at 050 inch Lift: 228
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 228 int./230 exh.
Advertised Intake Duration: 344
Advertised Exhaust Duration: 344
Advertised Duration: 344 int./344 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.585 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Quantity: Sold individually.
Notes: Computer modifications recommended for best performance.
