coolant temp sensor
coolant temp sensor
is there a difference between the two sensors? i know there is one in the block...and one in the water pump. and i have replaced the one in the water pump before..but never touched or looked for the one in the block. its supposed to be on the drivers side...right? is there a difference between these two sensors? im on napa tryin to order the sensor for the block and it shows me 5 sensors...all of which look the same!! lol so i was just wondering if there is a difference. thanks guys
So what if, when open loop kicks in, my fans are always on, but my gauge doesn't work :\ I replaced the pump one, still does it. I do think my TStat is stuck closed, since the coolant that leaked out from the sensor was greenish and in my radiator is brown, yuck brown, as in I"M GETTING A COOLANT SYSTEM FLUSH!
So yea, could it be that IF my TStat is stuck closed, my ****** running warm enough to kick the fans on, even if it's not circulating? (Which I've not blown anything, and it runs good) I'm confused :\ We'll see after the flush.
