T56 torque rating?
T56 torque rating?
How much SHP/torque can a stock T56 generally take before it blows?
I'm thinking about putting one in my V6 car. The car makes 550ft-lbs though, so I don't want to put in a tranny that will certainly blow up.
I don't really have the cash for a built up T56 either. I'd have to stick to stock right now.
It depends on several things. You first have to get the torque to the ground before the trans actually sees it. The higher numerical ratio sets ( 3.06/ 2.97/2.66 were available)will have a lower design torque rating. The early T56s also had narrower face-width gears that will lower their rating. That said:
3.06 and early 2.97 sets were rated at 350 lb-ft
later 2.97 and 2.66 sets 450 lb-ft
2.39( very limited availability) 600 lb-ft
newer sets :
2.66Viper 500 lb-ft
3.01 SSR 450 lb-ft
newer sets :
2.66Viper 500 lb-ft
3.01 SSR 450 lb-ft
Originally Posted by 3.4camaro
t56s have gone low tens in stock f-body form. you will be fine.
