dipstick on aftermarket pan ?
That's where mine is moutned as well. I have an LS1 and I'm using a 5.3 truck oil pan - so I also got the truck dipstick
I'd start by measuring the depth diff'ces of your aftermarket pan versus the stock pan. If there's that much difference, I'd think you may have other things to worry about ... like ... whether your oil pickup tube is going to actually pick up oil to keep things primed inside your block.
i have a 5.3 from a 04 buick rainer. it has a front sump. the oem dipstick is mounted to the side of the oil pan. i have the hole in the back of the block like rodder, but with my autokraft pan installed, the hole is outside of the oilpan lip. i'll have to find a different solution than what you guys use.
gday,doing a ls1 swap here in Australia,using Autokraft pan.all aussie ls1's have dip stick into the side of sump,looking for part number to install into block.motor has a hole with plug along the side,guessing this is correct spot?cheers Buzz
