On average what kind of timing are the turbo guys running?
On a built motor 8.5:1 with the AF around 11.5:1 what kind of timing are you guys running? Where does it peak and lower by high RPMs?
thanks
thanks
I know I'm just trying to get an idea of where my timing should be at. I'm running a 383 with #12, pump. Since the knock sensors are turned way down do to false knock I want to see where I should be around without getting knock.
Are you guys running the same timing across the board or different timing at lower (before full turbo spool) rpms???
I thought I read somewhere that higher timing before turbo fully spools will help with lag and spool it a bit quicker...
Anyone have any expertise on this?
Not trying to jack thread...think the original post was answered already...
