On average what kind of timing are the turbo guys running?
Old 04-28-2007, 05:23 PM
ABeasst's Avatar
Default On average what kind of timing are the turbo guys running?
On a built motor 8.5:1 with the AF around 11.5:1 what kind of timing are you guys running? Where does it peak and lower by high RPMs?
thanks
Old 04-28-2007, 10:09 PM
LS1Tech Sponsor
Slowhawk's Avatar
Matters on boost level and cubic inch motor ,gas quality ect.
Old 04-28-2007, 11:20 PM
ABeasst's Avatar
I know I'm just trying to get an idea of where my timing should be at. I'm running a 383 with #12, pump. Since the knock sensors are turned way down do to false knock I want to see where I should be around without getting knock.
Old 04-29-2007, 04:43 AM
Boostaholic's Avatar
17deg on full boost w/ 91 octane no meth
Old 04-29-2007, 01:11 PM
ABeasst's Avatar
thanks that what I need just whatever yall are running on pump gas.
Old 04-29-2007, 01:59 PM
firehawk123's Avatar
Iam running 18 deg on full boost w/ 98 octane,with meth 22 deg on full boost
Old 04-30-2007, 09:27 AM
SSblack98's Avatar
Are you guys running the same timing across the board or different timing at lower (before full turbo spool) rpms???
I thought I read somewhere that higher timing before turbo fully spools will help with lag and spool it a bit quicker...
Anyone have any expertise on this?
Not trying to jack thread...think the original post was answered already...
Old 04-30-2007, 09:32 AM
black98ws6ta's Avatar
Cylinder pressure will be high at peak torque....so most people run less timing there and ramp it back in by a few degress or so afterwards.
