Will 6 3/4 speakers fit my doors??????
They will fit in the door no problem. The only issue I know of is on a firebird/T/A. I don't know if camaros have this or not but my door has a plastic speaker mount that the speaker attaches to with 4 screws. That then attaches to the door itself. It is made specifically for a 6.5" speaker and not all 6.5" speakers fit well due to different baskets and such. You can very easily make you own by tracing the plastic and creating your own mounting ring out of mdf. Then you wouldn't have to worry about it fitting at all. Not to mention it would be way more solid then the plastic. Again..camaros have different door panels so I don't know if you have the same kind of mount or not. As far as depth...shouldn't be an issue at all. You won't have to cut anything on the door itself though.
