Whats needed for a head swap?
Its for my 96 T/A. I have a set of heads thanks for Juiced96Z. What ALL do I need to do the swap? I know the gaskets and head bolt..But exactly what gaskets and what head bolts? What all I needed? Thanks in advance
David
David
thanks viper yeah and if you read thru you can get a pretty good idea of what it entails but heres a small one:
-AFR heads
-GM head bolts
-GM MLS gaskets
-Water Pump Gasket
-Comp OEM lifters
-Hardened Chromoly Pushrods 7.35
-SVO 30# injectors
-Comp Pushrod length checker
-ARP thread chaser
-Tons of towels
-Lock-tight
-Fluids:
Oil 5w-30 hp 1007/antifreeze dexcool
-B-12 Chem-Tool
-Brake Cleaner
-AFR heads
-GM head bolts
-GM MLS gaskets
-Water Pump Gasket
-Comp OEM lifters
-SVO 30# injectors
-ARP thread chaser
-Tons of towels
-Lock-tight
-Fluids:
-B-12 Chem-Tool
-Brake Cleaner
