quick!! dif between 96 fbody/b body crank hubs and balancers
Old 04-30-2007, 11:44 PM
lt1mc's Avatar
Default quick!! dif between 96 fbody/b body crank hubs and balancers
hey guys. would i be able to run a 96 f body crank hub and balancer with a 96 b body motor/accessory setup?
Old 05-01-2007, 12:34 AM
lt1mc's Avatar
ttt. anybody know?
Old 05-01-2007, 08:18 AM
SAPPER's Avatar
No difference. Only the LT4 hub is different.
Old 05-01-2007, 10:25 AM
Karl Ellwein's Avatar
The b-body hub/damper combo will be a bit further away from the motor and won't line up with an F-body accessory bracket.
The fbody hub damper combo is different than the B-body which is different from the Y-body.
What you could do is space out the f-body accessory bracket whatever distance needed to line up with the b-body damper. Shouldn't be much more than 1/2"
Karl
Old 05-01-2007, 01:28 PM
lt1mc's Avatar
well actually i dont have the fbody accessory bracket. i have the b body bracket but need a hub and balancer. i found a good deal on the hub/balancer, but is from a 96 f body, which is why im thinking it will not work.
Old 05-01-2007, 01:40 PM
Right. that won't work.
The bbody bracket will not line up with the fbody hub/damper. The fbody hub/damper will be closer to the engine than if you had the bbody hub/damper.
Karl
Old 05-01-2007, 09:15 PM
lt1mc's Avatar
thanks man
Quick Reply: quick!! dif between 96 fbody/b body crank hubs and balancers
