More Black smoke when I floor it with cats gone.
Old 05-01-2007, 06:00 PM
Steve40th's Avatar
Default More Black smoke when I floor it with cats gone.
Without the catalytic converters on is it normal to see more black smoke when you intitially floor it? I noticed on the dyno and playing around with my little video camera that the car puts out some additional black smoke when you floor it or jab the throttle hard.
I do have low tension oil rings, and there is a little oil use and blue color in this video.
What do you think.
http://media.putfile.com/LT1-XE-2302...ng-and-revving
Old 05-01-2007, 08:24 PM
LT1Formula007's Avatar
I'd say as long as your not seeing it while regular driving your probably ok..... I cut the one off my 86 iroc with a built motor. Had full exhaust done w/o cat and it smoked a little more with the cat cut off. So I suppose it would be normal since you don't have the cat to catch all the exhaust and clear up the emissions. Hope I helped a little bit. Good luck
Old 05-01-2007, 08:37 PM
the_hunted's Avatar
do you have headers and full exhaust? I ask casue you may need to tune it and trick the computer to think there are cats there.
Old 05-01-2007, 08:56 PM
Steve40th's Avatar
pcnforless tuned it with the exhaust as it is. I had an O2 problem a while ago, maybe the data I sent was a little scewed as I went from unheated to heated O2's.
Old 05-01-2007, 11:01 PM
transam5.7lt1's Avatar
My trans am does the same thing, it does not have any cats on, it has an off road y-pipe, its does the same thing.
Quick Reply: More Black smoke when I floor it with cats gone.
