low oil pressure on 383
got my new motor in and running. but the most oil pressure we've been able to muster is 25lbs after repeated revs to 3000 rpms. it has a brand new high volume oil pump, and a brand new stock GM sending unit and a stock pan. and plenty of oil in it. what we have come up with is that with how much oil is being sucked through the new pump, the pickup must be too close to the bottom of the pan and its creating a "straw" or "scavenging" effect and not letting the pressure build up in the pan. solution being a deep sump pan, which is not exactly cheap, but a good investment. i just wanted some opinions before i bought one.
I have heard of people sucking the pan dry with a HV pump, but not at idle. I can suck mine dry in the quarter, unless it is very full. You said you have a new sending unit in the stock pan? The pressure sending unit is not in the pan.
i bought the motor brand new fully assembled. the engine builder put a high volume pump on it. the guys that put the motor in thought it would be a good idea to put a new sending unit on. and it currently has a stock pan. the sending unit is outside the pan right, runs along the drivers side?
the guy who put the motor in thinks the screen on the pickup is real close to the bottom of the pan, but was not sure. but we couldn't think of any other reason as to why it wasn't building enough pressure other than if it couldn't fill up under the screen as fast as it was being sucked through it.
Originally Posted by rob97ss
The problem is not the pan but the HV pump,put a stock pump on,it will be fine.
Put some thinner oil in it and try again. If it's better then that's you're problem. Sounds to me like either the sending unit is wrong, or there is a major bleed somewhere. I thought the port on the side of the pan was just to tell if there was oil at all, and not for pressure tho-?
From what I read you need a bigger pan with a HV pump. This is why I didn't go with a hv pump read plenty of horror stories about them.
I went with a high pressure melling and stock pan. I get 65-70 at startup and 45psi at hot idle. You might want to consider a high pressure pump too.
I have a 383 application also with a stock pan. I noticed that it sucks the pan dry, with 5 qts of oil. I just added one more qt, and seem to do the trick.
Oil Pressure Levels - 70psi cold startup------40psi normal opertating temp
I built my 383 and I get about 65 cold start and 45 hot while driving and around 25 hot idle. I use a stock style pump and it doesnt have no problem with oiling. A maximum of 35 on a new engine doesnt sound to good to me. Might be a little too much clearance on thosse bearings.
